Bridge between PC_DIMMER and DMXControl
    here are the plugins for DMXControl and PC_DIMMER. Please do following things:
    For DMXControl:
    1. Download the following file: http://www.pcdimmer.de/phpBB3/download/file.php?id=67
    2. Extract the DLL out of this ZIP-file and move it to C:\Program Files\DMXControl\Plugins\
    3. Start DMXControl and open the Pluginsetup (mainmenu -> "Configuration" -> "Plugins...")
    4. Activate the PC_DIMMER-Bridge Plugin
    For PC_DIMMER:
    1. Download the attached file to this post
    2. Extract the DLL out of this ZIP-file and move it to C:\Program Files\PHOENIXstudios\PC_DIMMER\Plugins\
    3. Start PC_DIMMER and go into the Advanced Options
    4. Activate the DMXControl Bridge-Plugin
    5. click on "Configure" and do a Search for the DMXControl Window
    6. If the DMXControl-Window has been found go to the DMXControl Pluginsetup-Screen and click on configure here, too.
    7. Do a search for the PC_DIMMER window
    That's it. Now you can change a value within PC_DIMMER or DMXControl and each program will send the values to the opposite.
    cu,
    Chris
