Useful Feature: Manual mode in Beat Tool
  • Hi Stefan! Thank You for so cool soft:) I am using the DMXControl is about 2 years and 1 year i control light in the night club.
    During this time I had a few ideas how to make the program more convenient for many users.
    Main idea is to add a manual mode in Beat tool.
    In manual mode the bpm counter only works when the tap button is clicked.
    if the tap button is not clicked the counter is not working and the red indicator not flashes and the scenes with duration "BEAT" is not switch.
    Manual BPM mode would be useful in those moments when a beat in the track has ended, or for light control during the thematic competitions.
    And it will be great for using BeatDetection plugin for definition a BPM from the line input, only when the beat in the track is present, or in break beat tracks, becouse this plugin counts very accurately compared to the plug-in for Winamp or Sound analyzer.
    Can I expect that this feature will appear in the next update?
    Best Regards, Sergey.
  • The feature you request is already available (indirectly): Simply use the "Sync"-Button instead of the "Tap"-Button. The "Sync" command generates a single beat event if the beat timer is not running. If it is already running, you can disable it with the "Reset" button.
    Kind regards,
  • Yes its work in full manual mode, but not with BeatDetection plugin(
    This plugin automatically "click" TAP when it finds a beat, and for correct switching scenes with sync in real beat we need disable predict bpm in BPM Tool.
    Maybe is it possible to add an option in the BPM Tool to disable the predict BPM. So if we turn on this parameter the TAP button will work as Sync button?
    Or need to modify the BeatDetection plugin so that he gave the signal to the Sync button and not on the TAP button in BPM Tool.
    Its possible?
    Thanks for the help! And sorry for my bad english :)
