how do you record static 'looks' to submasters?
  • hi,
    does anyone know how this is possible?
    assigning fixtures to subs is simple enough, but i don't seem to be able to setup looks on them.
    any solutions would be very welcome!
    that's easy,
    first create your scene in the Scene-library and name it "MyScene" or similar
    -> Window-> Show Scene Library
    or press "Ctrl+S"
    then go to your Submaster and klick on the "-" below the Fader.
    Choose "Command"
    a new Window will appear
    in the Dropdown choose "Scene Library" then choose "MyScene" and "Fade-In"
    just klick OK and The Fader will control your Static Scene.
    Regards, Souko aka Marcel
    I don't understand what you mean with "looks".
    Do you want to assign scenes from scenelist or effect-steps?
    That could be done by clicking on the "assign-dash" in the submasters and choosing "command". In the following box you select for example
    Module: scene library
    Device/function: <the scene you like>
    Channel: Fade in
    Flags: Nothing selected
    You can now even "Fade in" movements or colorweehls.
    I hope thats what you wanted to do.
    (Damn, Souku was faster ;))
  • thank you so much Hoc and Souko. i was sure dmxcontrol could manage such a simple function, i just couldn't put the pieces together!
    you've saved a show. if you're ever in NW UK, there's a cold beer or two waiting for you!
    Thanks, may be I visit some friends out there next year! ;) How do you use DMXControl? For what a kind of show? Just for the statistics. ;)
