Control from VBscript/command line?
  • Hey.
    I'm trying to send commands to dmxcontrol with vbscript.
    Iv'e done some scripting with homeseer before.
    I was hoping something simple as this would work:
    Set dmxc = CreateObject("DMXControl.Messages")
    dmxc.SetChannel ("1,125")
    Dmxcontrol starts when i run the script, bur i get this:
    Error: Object dosen't suport this property or method: 'dmxc.SetChannel
    Code: 800A01B6
    Is something like this possible?
    I also seen something about a dmxc.exe and som commands in the forum, tried that from command line with no luck.
    Will be very happy with some help to control DMXControl from vbscript or command line.
    I am not sure about the message-object but i can tell you, that there is no possibility to send commands via the commandline.
    Maybe the network-terminal-interface is the solution for you.
    Enable the experimentals in the menu: Settings, last point on list "Enable experimental tools".
    Then go to "Window" -> "PDA remote control"
    Now DMXControl listens on networkport 2145 or whatever you set it to. I am sorry, the wiki-page is german only, but the commands are in english anyway. ;)
    http://www.dmxcontrol.de/wiki/Terminal_Schnittstelle
    First column is what you send to the port, next column is the response, than "description" and "example".
    In your example you need to send "SetChannel 1 125" and DMXControl answers with "CV 1 125" if it was successful.
    The "RunCommand" is a little bit complicated since you have to step thru the "GetCommandPossibilities" to get the values you need. If you really need that we can try to translate it for you.
