Hello,
I have developped an interface USB-DMX which supports RDM assignation. This interface will be soon available.
I have developped a plugin for DMX Control, because it's a great software. I have based this plugin on an demo in delphi proposed on the wiki.
To update the value of DMX it uses :
TOutputPlugin.SetChannel(Channel, Value: Integer);
But there is a problem with this function. When we use Flash button on the soft, all value aren't update in same time (there is often a little latency and this is visible on a RGB led driver).
So my question, is there an other function which permits to update a lot of value in same time? (The function will receive in paramaters a vector). Or is there a signal (variable) which prevents the plugin that a flash button is pressed and so there is a lot of value to update?
I hope you understand my question. Sorry for my poor english
Best regards
Benjamin
