Ver 2.10 - BeatTool>BpmValue>Set & Submaster>Flash># No work....
  • In Ver 2.10 -
    When I set a command to trigger BeatTool>BpmValue>Set
    Nothing happens. The beattool does not take the value.
    The Tap command does work and is what I have been using instead to set a BPM to a timeline.
    When I command a Submaster>Flash, it does not trigger a flash,
    it toggles it on and stays on. No matter what setting the submaster is set to.
    Also, it will not toggle off, only on.
    Are these known bugs?
    Thanks so much for everything.
    :D
    Original von newton2013
    I just tested the command and it worked for me. How ist the command configured? If the flag "Ignore value 0" is set this will result in the reported error.
  • If I place Submaster>Flash>3 into a timeline or effect,
    no matter if set to Toggle, Value (tried different values), or neither,
    it toggles Submaster channel 3 on, and it stays on.
    Toggling it again using the same method does nothing, it stays on.
    If I click the 3 button within the submaster itself, it flashes correctly.
    Clicking the 3 button there also resets the 'On-ness' from the effect/timeline trigger.
    What is it supposed to be set to to simply toggle a single flash?
    I never did understand the values as it asks for 0-100,000, takes 0-100.
    All values trigger on. no flash.
    Submaster flash mode is set to Flash.
    Submaster Channel 3 is currently set to the Green channel of a minspot for testing, dimmers are set correctly.
    Sorry for lack of elaboration earlier... :)
    Thanks Again!
    Edited 2 times, last by newton2013 (March 8, 2009 at 4:33 AM).
  • Also, would it be possible in future updates to add commands such as...
    Effect>EffectOneName>Playmode : Norm, Bounce, Reverse....
    and
    Effect>EffectOneName>Beattriggered : On, Off
    So far I just copy the effect and make one beat triggered, and one not.
    Same with playmodes... a copied effect set to bounce, and a copy set to reverse.
