In Ver 2.10 -
When I set a command to trigger BeatTool>BpmValue>Set
Nothing happens. The beattool does not take the value.
The Tap command does work and is what I have been using instead to set a BPM to a timeline.
When I command a Submaster>Flash, it does not trigger a flash,
it toggles it on and stays on. No matter what setting the submaster is set to.
Also, it will not toggle off, only on.
Are these known bugs?
Thanks so much for everything. ![]()
