Manolator interface
  • Hi
    I been trying to get the Manolator interface to work with DMXControl. But I haven't got any luck. I have problem with the dmx response and it even get worse with faster computers. The one I'm using now is a P4 3 GHz and I get 2-3 seconds delay from that the value of a dmx-channel is set to that the actual value gets to the dimmer. With a PIII 600MHz I got a delay of about 100ms. The interface works fine with other dmx software, so there is nothing wrong with the hardware.
    Has anyone got the Manolator interface working with Dmxcontrol or should I simply giveup on the Manolator interface?
    Regards Magnus
    Now all the timing parameters are user-adjustable so you can tweak it for optimum performance with your system.
    Please report the settings you found, thank you.
    Thanks, now it's starting to work. With "Start signal length" at 10000us and "update interval"at 25ms are the response time OK. Not perfect but OK. Can you make a version with "Start signal length" max at 30000us? Or is it possible to get the source for the output plugin and make some test of my own?
    Magnus
