Audio Player
  • I may be dumb, but using the audio player to trigger submaster flash commands, at time points on the audio waveform, I get lights stuck on when I ask for a flash.
    Changing the submaster mode of operation (Normal, On/Off or One On) has different results but none will allow a flash.
    I realise it is still experimental, but if this glitch could be overcome it would make a superb DMX sound sequencer like Lite O Rama for controlling holliday lights
    Holliday lights? ;D I think I know what you mean...
    Perhaps the "Highest Takes Precendece"(HTP) in "program configuration" may be deactivated. This could make your lights stay on.
    But a warning: Don't expect to much for your project, the audio player is not yet precise enough for fast changes/flashes if you do it that way. Start "flash-scenes" of effects on quick flashes instead of trying to mark every beat on the waveform... I tried it but gave up. For now... ;)
  • You know what he means?
    Explain please :)
    I'm going to do a show with the audioplayer, so I'd like to know about the problems...
    For you, DayLion, here is the hint to the german Discussion:
    http://www.dmxcontrol.de/cgi-bin/yabb/Y…;num=1133266870
    And here is the ultimate "holiday lights" i know that uses light-o-rama. I think thats what jaybee wants to to... ;)
    (And perhaps I do a small version of it next winter...)
    http://www.snopes.com/photos/arts/xmaslights.asp
