bounty! midi output plugin!
  • i'd realy like midi out,
    that way i can use dmxcontrol to control everything, i have lots of equipment that i control from midi. like a video mixer,and audio player, a sampler, my arkaos, (too poor for dmx version).
    right now i'm doing a show that would be much easier if i could send midi events from the cue list.
    i don't know what the official policy on bounties is, so i hope its o.k.
    i'll like to offer a bounty of €50 euros for a plugin that supports midi out, that i can acesss like the other devices in dmx control.
    all i realy need to be able to do is send a command from the cue list, sending a midi note. i do not need continuous controlers.
    if you are interested, send me an email,
    ewanuno@gmail.com.
  • Hi ewanuno.
    I've programmed a DMXControl Plugin for you, that outputs MIDI-Data. You can find it in the Wiki: Wikilink
    Download the file "MidiOutput.dll" to
    "c:\Program Files\DMXControl\Plugins"
    If the folder does not exist, create it :)
    You will find the plugin in Mainmenu->Configuration->Plugins... or Mainmenu->Windows->MidiOutput
    Here is the Deeplink to the File: MidiOutput.dll
    External Content youtu.be
    Edited once, last by Blackout-Chris (March 11, 2008 at 2:45 AM).
  • for those in the forum,
    the plugin works well,
    heres chris's instructions that he emailed me,
    quote:
    I’ve got no access to the command-module. I’ve talked to Stepha Krupop (the programmer of DMXControl) and he said the access is planned, but not ready yet. So I had to program it as a standard plugin for DMXControl. The plugin receives all changes you make for a dmx channel. So you have to control your Midi-Messages over DMX-Channels.
    Small example:
    1) Add a new event within the plugin-window and select it
    2) Set a channel (like chan=400) within the chan-field
    3) Use the command “Send MSG with Data1=Channelvalue”
    4) Setup MSG=144 (this is the message for standard notes)
    5) Put 127 in the field “Data2” (volume=max)
    6) choose a MIDI-Driver in the top area of the plugin (use the standard Microsoft Wavetable Synth for this test)
    7) go into the DMXControl channeloverview and search for channel 400 and select it
    8) move the slider on the left side
    9) now you should hear an great arpeggio from the lowest tone to the highest.
    You can send single midi-messages with use of the last option in the plugin (values). Set this value to 254 and use the event-type: “Send static MSG if Channelvalue>Value”. Whenever the dmx-channel is over 254, the setup midi-message will be sent over midi.
    This solution with this plugin is just a workaround, but the next DMXControl version will be able to use Midi-Output over commands (I’m a coprogrammer of Version 3.0 – release is planned for next year).
    unquote.
