Position Mapping Alignment Issue?
  • Hello folks,
    (German down below)
    I am playing with the new position mapping in the 3.3.2. It is a fantastic feature and will be extremely useful for me. Thank you!
    I have a room layout as shown below.
    - The moving heads are symmetrically on both sides of the room.
    - They have been calibrated in a position mapping to corners 1-4 to overlap (in both lower as well as upper reference planes)
    - Then set to the center position in the programmer and turned
    - In that position, they shine into the respective spots, but do not overlap at all (especially side to side, there are meters in between the two rows.
    - In the corner positions they overlap well.
    So my question is what am I doing wrong that they are not overlapping better in the middle positions?
    I can get the two rows to overlap a bit better by adjusting the "normal" value, but that of course throws off the corner mappings.
    I have also tried using cartesian or polar coordinates in the mapping but cartesian does "weird things" compared to polar.
    Understandably the side-to-side offset *could* be alignment error, but it is about half a meter off or more.
    There is no way I got the front-to-back alignment between both rows of heads far enough off to cause several meters of distance.
    So again, what am I misunderstanding and how could I fix that?
    Thanks in advance!
    Hallo zusammen,
    ich teste gerade die neue Positionszuordnung in Version 3.3.2. Sie ist fantastisch und wird mir sehr nützlich sein. Vielen Dank!
    Mein Raumlayout sieht wie folgt aus:
    – Die Moving Heads sind symmetrisch auf beiden Seiten des Raums angeordnet.
    - Die Scheinwerfer wurden so kalibriert, dass sie sich in den Ecken 1-4 überlappen (sowohl in der unteren als auch in der oberen Referenzebene).
    - Anschließend wurden sie im Programmer in die Mittelposition gebracht und gedreht.
    - In dieser Position leuchten sie zwar in die jeweiligen Bereiche, überlappen sich aber überhaupt nicht (insbesondere seitlich; zwischen den beiden Reihen besteht ein Abstand von mehreren Metern).
    - In den Eckpositionen überlappen sie sich gut.
    Meine Frage ist also: Was mache ich falsch, dass sie sich in den mittleren Positionen nicht besser überlappen? Ich kann die Überlappung der beiden Reihen etwas verbessern, indem ich den Wert für „Normal“ anpasse, aber das verändert natürlich die Eckzuordnungen. Ich habe auch versucht, kartesische und polare Koordinaten für die Zuordnung zu verwenden, aber kartesische Koordinaten verhalten sich im Vergleich zu polaren merkwürdig. Verständlicherweise *könnte* der seitliche Versatz auf einen Ausrichtungsfehler zurückzuführen sein, aber er beträgt mindestens einen halben Meter. Ich kann unmöglich die Ausrichtung der beiden Scheinwerferreihen so weit verstellt haben, dass ein Abstand von mehreren Metern entsteht.
    Also nochmal: Was mache ich falsch? Ich habe ein Missverständnis festgestellt und wie kann ich es beheben?
    Vielen Dank im Voraus!
