Creating DDF file for ADJ lights
  • Hello Guys iv new to DMXcontrol3 and I was trying to use the stage view and device control. I couldn't find my light fixture, so i made my own. However I'm having a problem with my code. I have a problem with RGB, the different channels I put in here will only work if the colortemp channel is set to between 0-15 and if the value is above 15 the colortemp channel overrides everything which is what I want. In device control when I go to the color temp I have a slider where I can see my temps and at the end of the slider it says "empty" but when I move it there and check the channel overview channel stays at 16 but i need it to be between 0-15 in order for RGB to work. If I could get some help in understanding why when the slider goes to empty it stays at 16 that would be awesome ( disregard channel 5 I need to fix that so it also has sliders).
    <rgb>
    <red dmxchannel="0" />
    <green dmxchannel="1" />
    <blue dmxchannel="2" />
    <amber dmxchannel="3" />
    <lime dmxchannel="4" />
    </rgb>
    <rawstep dmxchannel="5" name="Macros" >
    <step caption="No Function" mindmx="0" maxdmx="0" />
    <step caption="Color Macro" mindmx="1" maxdmx="196" />
    <step caption="Color temp macro" mindmx="197" maxdmx="255" />
    </rawstep>
    <colortemp dmxchannel="6" defaultval="6000" >
    <step type="off" mindmx="0" maxdmx="15" />
    <range minval="2300" maxval="9900" mindmx="16" maxdmx="255" />
    </colortemp>
  • nutzer99 February 23, 2026 at 9:51 PM
