Good Day All!
So today I have the chance to play around with a fixture with blades again.
I have discovered a way the blades on this particular fixture work:
Each blade has 2 parameters. Example:
Ch. 18. Blade 1_A
Ch. 19. Blade 1_B
At first I was losing my mind, because The blade would not work linearly.
Then I realized. In order to make the blade move linearly (Straight Up and Down) Both Ch. 18 and Ch. 19 must be operated at the same time.
To rotate one way or another, Blade 1_A or 1_B would have to be adjusted individually.
So it pivots from each corner.
Now I know currently the syntaxt for Blade control is a bit limited, but it begs 2 questions.
1. With the current blade control syntax, is it possible to program the DDF to behave in this way (Rotation and movement based on left and right blade rotation/movement), rather than one channel for linear movement, and another channel with range to control rotation on center?
2. If that is not possible, can a RAW channel be created that simultaneously effects 2 channels with one slider or Parameter change?
