Hello DMXC Friends.
Simple Question (Hopefully)
Is it possible to add more than 2 universes of Direct DMX In / Out in the Input Assignment?
Great Thanks ![]()
P.S. Happy Thanksgiving [Frohes Erntedankfest!]
Hello DMXC Friends.
Great Thanks ![]()
Hey!
Funnily we had the same question in the German area: Gibt es in der Eingangszuweisung mehr als zwei DMX-Out Universen?
The short answer is: no, because the DMX-In-Channels at the Input Assignment are only for controlling DMXControl 3 with an classic DMX Controller. When you simply want to pass through more DMX channels, then we have the function called "DMX-In DMX-Out Mapping". That you can find at the settings.
Thanks Stefan. I had an idea that was the case.
Is individual fixture control still possible thru input assignments?
Or would that better be implemented now thru Submasters/Executor?
Almost right... For individual control of devices you use the different type of masters depending on the function you would like control. This will create at the end again a cuelist with cues.
