Hi, I am trying to create a device using arduino and a DMX / RDM shield to give an address to a DMX/RDM slave. However every example and library I found online only allows the arduino DMX control as a master, or DMX/RDM control from another master (that means arduino is a slave, which already has a DMX start address-not my point). More specific, I have a set of 10 lights, each one is RGBW (4 footprints) and I want using the arduino to be able to set their addresses accordingly at will. Any ideas?? Thank you very much in advance!
