Hi guys,
I'm using some moving lights with 16-bit pan/tilt resolution.
I've noticed that when I use effects such as Sinus or Triangle to control the movement and the speed is very slow, it becomes very jerky - it looks like it's only being output in 8 bit resolution, or maybe the effect output is only being calculated and updated every half a second
If I create a similar speed of movement with cues the lights move very smoothly, so the device DDF is definitely configured correctly for 16 bit.
Do you have any idea why this is happening and is there a way to fix it?
All the best,
Phil
