Combining DMX values from two sources
  • Hi all,
    I'm using Resolume Arena (video playback software) to drive some LED strips via ArtNet, and I was wondering if it's possible to configure DMXC3 to combine the DMX values from Resolume with values from an LED Driver device in DMXC3 on a HTP basis so that I have the option to control the LED strips using either piece of software?
    I would imagine this is possible using the Input Assignment, but I've had a look at the Input Assignment nodes and I'm unsure how I would combine these two sources and output to DMX.
    I presume I can read the values that Resolume is outputting using the "DMX-In" nodes, but I'm unsure what node I would use to read the values from the LED Driver Device in DMXC3?
    Additional information: I have 6 LED strips, and each LED strip uses 6 channels - Dimmer, R / G / B / W, Strobe. I've already created & tested a device in DMXC to control these.
    Any advice on whether this is possible and how to configure it would be much appreciated!
    Cheers,
    Phil
