List of active cuelists?
  • Hello!
    An first indication, which cuelists are running, is the channel overview. At the bottom of this window, you can find a list. But yes, a separate list, which cuelists are running at the first and which of them are finally responsible for the output the devices (due to priority and the mixing mode) is currently not available. There is only for the moment the feature request in our bugtracker (in German): FS#3121 : Neues Fenster: Engagement Monitor / Control Monitor
    For stopping all running cuelists, there you should see a button in the quick menu on the left in the main window. Additionally you can use this function also with the "All cuelist" Node or the "Cuelist group" node in the input assignment.
    Best regards, Stefan.
  • >> At the bottom of this window, you can find a list.
    Thank you Stefan that's great
    Oh! I can't believe I didn't see that before :D Thank you
