MIDI Question
  • MIDI question
    I am trying to send commands to DMXControl 2.12 from Multiplayer (https://da-share.com/forum/index.php) a tool we are using for our Theatrical production in order to automate the light changes.
    Environment: I have Multiplay (3.0.176) sending commands to loopMidi (v1.0.16) and, from there, to DMXControl 2.12.2 (on the same pc).
    What I have done:
    I have created two MIDI cues into Multiplay:
    Q | Status | Channel| Address
    Q1 | program change | 1 | 1
    Q2 | program change | 1 | 2
    Q1 will fire Chaser1 that is turning all the front light (6x dimmer) up to 255
    Q2 will fire Chaser2 that is turning all the front light (6x dimmer) down to 0
    What is happening:
    Sending Q1 works as expected as well as Q2, BUT, these chasers stay active and if I need to run again Q1... nothing happens.
    I know, DMXControl 2.12 is no more supported and on top of that I am not a MIDI expert... but someone over there could try to explain which is the best way to have each Q executed and, at the end (assuming Q2 is the end), both Q1 and Q2 will stop ?
    As always many thanks to all of you.
    Regards
    Luca
