Art-net output?
  • Hello.
    I am having a little difficulty having the art-net output plugin work.
    I am trying to have it interface with freestyler's art-net to DMX software converter.
    What is the use of "subnet"? What is the use of "port"? Is the scan button supposed to detect the Freestyler node?
    Is the art-net output plugin supposed to work at all?
    Thanks!
    Stanislas
  • Hi all!
    Well, I found the problem. I was trying to use the freestyler art-net to dmx software on the same computer I was using DMXcontrol. Both software were fighting for the listening port.
    Now, my problem is this : is there anyway to disable the input capability of the art-net plugin for dmxcontrol? I really want to use both software on the same computer and I don't want DMXcontrol to be listening to art-net, I just want it to send art-net...
    How can I do this?
    Thanks!
    Stanislas Elie
  • Hum...
    No answer...
    Could anyone tell me who made the art-net plugin? I would like to contact him and perhaps get the source code, so I can modify it myself...
    Thanks all!
    Stanislas Elie
  • Oh, I am sorry. ::)
    I'm the author of the ArtNet-Plugin.
    In the last version, it always tried to send the ArtNet-data on the default ArtNet-port. When two ArtNet-clients are running on the same machine, the output port will be blocked by the other application.
    I updated the plugin now, so that it will try another local port if the default port is blocked. In this case the plugin is able to send ArtNet, but receiving ArtNet will not be possible. When the default port is released, the plugin will return to normal.
    Are there any plans for a DMXC version of the Art-Net to DMX application like the application that comes with Freestyler?
    Thanks...
