PC Requirements?
    First off, I really like this project, it's great! I've work with several professional systems that couldn't match dmxc.
    Right now I'm at the point that I'm planning a 'controller in a box' solution with a control surface and a dmx output. I allready have all the material at hand which includes: a 12" touchscreen, a 4 axis joystick, 1 midi surface and one midi keyboard. DMX will be sent out using the velleman kit.
    As I'm a bit of a handyman I'm planning on putting it all nicely together in one box together with the pc, and that's where my question starts: how much computing power do you need to run dmcx smoothly? I get to do some pretty big shows from time to time, so I can't afford hangups.
    I was planning on using a VIA epia m9000 board which has a 933mhz processor because of it's small form factor (and because I have it lying around). Is it enough?
    That depends on what you do. :)
    If you use the audioplayer or the Sound2Light features this may be not enough Power in some strange conditions.
    On the other side, the system is clean and no unnecessary progams or services run in background.
    Basically for all normal "party operations", it is enough.
    If you already have all parts lying around, max it out and try if it is working. :)
    (Please someone else confirm or deny my statements, I have no "real big" shows running at the moment. But I have an AMD 1GHz, that may come close to your equipment.)
