I'm sort of somewhere... I dont know why cue 2 stopped working after copying, but I deleted it, and copied cue 4 in its place and its is working now.
I've disabled tracking and I think I'm somewhere near having a workable replacement to "save all" from DMX 2.
I understand Stage View just shows DMX output (and programmer)- but obviously that is what I use to programme and set cues so thats my main view.
The only bit I need to get my head around...
So say I programme 20 cues for the show and want to just run back through them...
1. In between programming them, as long as I dont then run an cues I dont need to clear the programmer do i? Clearing that after every cue seems quite a chore.
2. I DO need to clear the programmer before I run the cue list to test, and I also need to clear it after I've run the cue list before I start programming more cues in again... but then I dont need to clear it again until I want to run the cue list again?
3. If when I programme a cue in, with tracking turned off, when i run a cue it will turn everything thats currently on off, and turn on only what's programmed?
