Posts by Stefan Krupop
    It sounds like you are using the "Cue list" tool, which is not the best selection for what you are trying to achieve (it is meant for a sequence of cues for e.g. theater use).
    Using the "Chasers tool" will give you much more options for chasers and is what the "Chasers" in the commands refer to.
    Kind regards,
    Stefan
    Ich meinte das noch geringfügig anders:
    3. Haltezeit viel zu lang für den eigentlichen Einsatz einstellen (z.B. eine Minute)
    4. Den Effekt mittels Start/Stop und "Einblendzeit verwenden" (so wie im Befehlsszenen-Fenster beschrieben) starten, wobei die (durch den Balken angezeigte) Einblendzeit dann der Dauer entspricht
    So hat man mittels des angezeigten Balkens eine Rückmeldung darüber, wie lang die Szene geht und sie wird "rückstandsfrei" wieder abgeschaltet.
    Stefan
    Then the delay problem is caused by a specialty of your interface: It is capable to output less than 512 channels to speed up the refresh rate of the DMX universe. This can lead to problems with certain DMX devices which are not completely DMX-512 standard compatible.
    The problem is "fixed" by the blackout because this forces the interface to send all 512 channels. When you power-cycle the interface, the problem would reoccur.
    If I remember correctly, the minimal number of channels to be sent can be configured with the configuration tool from DMX4all.
    Kind regards,
    Stefan
    Is the delay in the DMX output also observable in the "Channel overview" window? If it is not, there's probably something wrong with the interface or there is a compatibility issue between your LED PAR and the interface (which can sometimes happen and has nothing to do with the software).
    Stopping a chaser when another one starts is no problem for DMXC. Group all the chasers you want to be mutually exclusive by adding a group name in parenthesis (e.g. "Chaser 1 (LEDPAR)"). Then enable the option "Execute only one chaser per group" in the chaser tool.
    Cues in DMXC use a "tracking" approach, as found in many lighting consoles. Each cue only saves the channels which where selected by check marks and leaves the other channels alone. This gives a lot of flexibility necessary for many projects. For you it means you will have to select all channels you want to change, even when this change is "setting the channel to zero".
    Kind regards,
    Stefan
    Das sollte über die Funktion "Nur starten wenn keiner läuft" des Effektsequencers klappen.
    Einfach für jeden Buzzer einen entsprechenden Effekt anlegen (da kann auch eine Audioszene für den Sound rein) und die über die Tastatursteuerung mit den entsprechenden Tasten verknüpfen. Wenn der Effekt nicht auf "Wiederholen" steht und die letzte Szene z.B. eine Dauer von 20 Sek. hat, kann erst nach Ablauf der Zeit ein neuer Effekt gestartet werden.
    Das ganze geht genau so natürlich auch über ein umgebautes Gamepad mittels der "Joysticksteueung".
    Stefan
    Wenn HTP in der Programmkonfiguration aktiviert ist, sollte es ausreichen einen Effekt mit nur einen Szene zu erstellen, in der alle Dimmerkanäle auf den gewünschten Vorglüh-Wert eingestellt sind. Durch HTP werden die Werte überschrieben, sobald irgend ein anderer Programmteil einen größeren Wert ausgeben will. Wird der Effekt beendet, verschwindet auch der "Vorglüh-Wert".
    Stefan
    Das Interface von DMX4All ist schon ein aktives, also mit eigener DMX-Signal-Erzeugung. Aber die DMX4All-Interfaces haben zumindest teilweise die Fähigkeit, weniger als 512 DMX-Kanäle auszugeben, womit manche Geräte aber Schwierigkeiten haben können. Versuche doch mal, über die Kanalübersicht von DMXC den Kanal 512 auf einen Wert ungleich 0 zu setzen, um so das Interface zu "zwingen", ein komplettes Universe auszugeben.
    Stefan
    Nur die Grafische Bühnen Ansicht hat seit der 2.11 (sinnvoller weise) eine höhere Priorität wie alles andere. Deshalb gibt es dort jetzt auch den "Reset"-Button.
    Das stimmt allerdings nur teilweise. Prioritäten gibt es in DMXC aktuell nur an zwei Stellen und dort auch nur, wenn der Benutzer es "angefordert" hat:
    1) Einzelne Geräte können in der grafischen Bühnenansicht eine höhere Priorität bekommen (im Kontextmenü), damit man quasi "die Kontolle übernehmen" kann, ohne dass z.B. ein neu gestarteter Effekt dazwischen funkt. Ansonsten hat die grafische Bühnenansicht keine höhere Priorität und HTP/LTP kommen zum Einsatz
    2) Einzelnen Effekten kann eine Priorität zugeordnet werden, damit sie andere Effekte immer überschreiben. Standardmäßig haben Effekte aber die gleiche Priorität wie alle anderen Module auch.
    Stefan
