Mit den Stichworten
sollten sich jede Menge Gehäuse finden lassen, in die man dann einbauen kann, was man braucht.
Stefan
Mit den Stichworten
Stefan
Wenn du eine Zweikanal-Platine nimmst, kannst du die Relays einfach in Reihe schalten und hast somit eine Absicherung.
Ich würde das genau wie von Paradieshenne vorgeschlagen in Hardware lösen: Einfach den Strom der Reihe nach durch beide Relais (oder sogar alle 3 ;-)) leiten. Erst wenn beide angezogen sind, kann der Strom bis zum Shooter fließen.
Stefan
Übergangsweise kann archive.org aushelfen:
https://web.archive.org/web/2019020519…oelscher-hi.de/
Stefan
Ein entsprechender Fix funktioniert bei MS intern wohl schon:
Official update so far:
"We will release a fix for this issue over the coming days as part of the ‘optional’ C update, which we are releasing early to address this issue. Note we are confirming which channels customers can pick up the update. Windows Update for Business customers will need to apply the update via Microsoft Update Catalog or Windows Server Update Services (WSUS)."
Translation: We have a fix that we have tested on some platforms, and still waiting on testing in other platforms, and our release schedule will depend on which version of Windows you have, and how you obtain updates. In some cases, I think the release may even be this afternoon. In other cases, maybe another week or so. Or somewhere in between.
That's all I have for now.
Inzwischen gibt es auch eine Beschreibung eines MS-Mitarbeiters, was eigentlich passiert:
https://answers.microsoft.com/en-us/msoffice…60-0a220f1656e9 (Beitrag von "ScotBren")
I am a Sr. Escalation Engineer for Microsoft, and we are already working multiple support cases that have been opened for this issue. The update that was released yesterday contained a change in the oleaut32.dll that mitigates a specific security exploit. Unfortunately, this mitigation unexpectedly caused all these VBA and VB6 apps that were passing an empty ParamArray to start getting E_INVALIDARG in return from an internal function call. This bubbled up to the errors you are seeing.
We are taking this very seriously and discussing the possibilities for a safe and quick way to resolve this. Since it was caused by a security update, there may be some obstacles to simply reverting the changes we made.
Nevertheless, our full attention is on this issue now, and please rest assured that we will provide an update when we can safely do so.
In the meantime, if you are at liberty to modify your code, passing a parameter to the ParamArray, even if you don't need it, should avoid the problem.
Scot
Stefan
Das Problem ist inzwischen bei Microsoft bekannt und wird hoffentlich behoben. Der aktuelle Status scheint hier zu finden zu sein:
https://docs.microsoft.com/en-us/windows/…1903#629msgdesc
Auch im KB-Artikel zum Update selbst wird das Problem angesprochen:
https://support.microsoft.com/en-us/help/451…pdate-kb4512508
Stefan
Kann es sein, dass es mit folgendem Problem zusammen hängt:
Ich kann es nicht ausschließen. Aber auch wenn "Translator" so klingt als könnte das an irgendwelchen Texten liegen, scheint der Fehler wohl bei allen Methoden aufzutreten, die bestimmte VB-Features benutzen (evtl. ParamArray?). Der Translator ist halt zufällig die erste Stelle, im Startprozess von DMXC 2, der diese Features nutzt...
Stefan
Es sieht so aus, als könnte das Windows-Update KB4512508 von gestern für dieses Problem sorgen.
Als schnellen Würg-Around könnte es helfen, dieses Update (temporär?) zu deinstallieren.
Stefan
Der "Translator" ist in DMXC eigentlich für die Sprachübersetzung (Deutsch/Englisch) zuständig. Das sollte nichts mit Treibern auf dem System zu tun haben...
Kannst du bitte einmal einen Screenshot der Fehlermeldung anhängen?
Stefan
denn sonst hätte die Prüfung in Modus 6 ja auch keine Werte im Input geben dürfen, welche allerdings erschienen.
Wenn sowohl Ein- als auch Ausgang falsch angeschlossen sind, "versteht" das Interface sich selbst einwandfrei und der Loopback-Test funktioniert. Nur können andere DMX-Geräte (außer nicht umgebaute alte Martin-Geräte ;-)) damit nichts anfangen...
Stefan
In solchen Fällen lohnt es sich erstmal, die Belegung der XLR-Verbinder am Interface noch mal genau zu überprüfen. Meist ist da was vertauscht.
In Kapitel 6.1 der Aufbauanleitung ist die richtige Belegung gezeigt. Pin 2 der Platine führt nämlich an Pin 3 der Buchse und umgekehrt. Nicht einfach 1:1!
Stefan
Eigentlich alle Splitter, die ich bisher gesehen habe, arbeiten auf OSI-Schicht 1, verstehen also nichts von DMX selbst. Sie haben nur einen RS485-Transceiver zum Empfang, an dem dann wie hier 8 Transceiver zum Senden hängen. Was an Signal rein geht, geht auch wieder raus, auch wenn zwischendrin zwischen differentiell zu nicht-differentiell und zurück gewandelt wird. Am Timing ändert das aber nichts. Bessere Splitter haben dann noch galvanische Trennung zwischen den Transceivern, aber auch das ändert eigentlich nichts.
Stefan
Interessant wäre zu wissen, welches DMX-Interface du einsetzt.
Stefan
Ich bin verwirrt... Laut JMS Website hat die PRO-Variante gar keine LED am XLR?
Nach dem erneuten hinzufügen leuchtet die LED dann?
Kannst du zufällig ein Foto vom Innenleben machen, wo man erkennen kann, wie die LED angeschlossen ist?
Stefan
(erkennbar daran, dass das rote Lämpchen drinnen nicht leuchtet)
Hast du die PRO-Variante (von der im Thread-Titel die Rede ist) oder die "OPTO"-Variante mit insgesamt 3 LEDs (eine im USB-Stecker, zwei im XLR-Stecker)?
Die LED im USB-Stecker leuchtet also, aber die am XLR-Stecker nicht? Keine von Beiden?
Stefan
Kannst du mal versuchen, den letzten Punkt der Figur genau auf den Ersten zu legen? Ich kann mir vorstellen, dass es im Relativmodus ein Problem mit dem "schließen" der Figur gibt...
Stefan
Ich habe das Eurolite-Ausgabeplugin mal etwas angepasst in der Hoffnung, dass das Problem jetzt nicht mehr auftritt. Einfach die bisherige Dateien unter Kernel\Plugins\ ersetzen. Ab DMXC 3.2 wird die Änderung dann auch mit ausgeliefert werden.
Kannst du das noch mal testen oder hast du das MK2 nicht mehr?
Stefan
Je nachdem von welchen Programmen die Netzwerkschnittstelle auf dem Pi gemanaged wird, kann man durchaus eine feste IP-Adresse als Fallback einstellen. Dann versucht der Pi immer zuerst, über DHCP eine Adresse zu bekommen. Klappt das nicht, wird eine vorher eingestellte feste IP verwendet.
Für dhclient kann man in der dhclient.conf in etwa folgendes eintragen:
timeout 10;
lease {
interface "eth0";
fixed-address 192.168.0.10;
option subnet-mask 255.255.255.0;
renew 2 2099/1/1 00:00:01;
rebind 2 2099/1/1 00:00:01;
expire 2 2099/1/1 0:00:01;
Kommt der NetworkManager zum Einsatz, kann man zwei Verbindungen für eine Schnittstelle anlegen: Einmal DHCP mit höherer Priorität und eine zweite mit fester IP, aber niedrigerer Prio.
Dafür braucht es aber wohl etwas fortgeschrittene Linux-Kenntnisse... ![]()
Stefan
D.h. also, bei "DMX Interfaces" müsste bei "Port" automatisch die richtige Nummer eingetragen werden? Bei mir steht da "0"
Nein, in der Spalte stünde bei Interfaces mit mehreren Universen der Port, an den das Universe ausgegeben werden soll. Mit dem COM-Port des Interfaces hat das nichts zu tun, der wird nirgends angezeigt.
In den Logfiles habe ich nichts auffälliges bzgl. des Interface gesehen...
Ich habe es mal mit dem vereinseigenen NanoDMX probiert, da hat es auf Anhieb funktioniert... Komisch...
Stefan
DMXC 3 benutzt im Unterschied zu DMXC 2 die DMX4ALL.dll, die von DMX4All zur Verfügung gestellt wird. Ich schätze, der DMX-Configurator benutzt die auch?
Wirf bitte einmal einen Blick in das Log des DMXC-Kernels (geht über das ?-Menü in der GUI). Wenn das Interface nicht geöffnet werden kann, müsste es dort eine entsprechende Meldung geben.
Dass das Einstellungs-Fenster leer ist ist in Ordnung. Die DLL müsste das Interface selbstständig finden.
Stefan
