Sending Midi Show Control from MidiOutput?
  • Hi all
    I've upgraded DMXControl to 2.11 and installed the MidiOutput 8.0.2 plugin.
    I'm primarily working from the TextBook tool, triggering audio etc.
    My problem is, that I'm trying to send cue-messages to a grandMa via Midi Show Control messages, but I'm unsure if this is supported by the plugin.
    The specification to the extention of the midi protocol is found here:
    http://www.richmondsounddesign.com/docs/midi-show…ecification.pdf
    Am I barking up the wrong tree?
    Is there some better way to send MSC messages from DMXControl - maybe an external tool?
    Best regards
    Rune
  • Unfortunately the plugin does not support MSC.
    However you could use Midi Yoke and MIDI-OX to translate the MIDI Messages from DMXControl (like Note On or so) to MSC. In the Data Mapping Window of MIDI-OX you can set the Output Event Type to SysEx and send static MSC commands.
    Dennis
