Newbee need help badley
  • Deal Forum,
    I am testing like creasy but having the same problem over and over again. Started a frech install but keep running into problems with the pluginadmin. It seems to be rightprotected (even in admin-mode). OS=vista. Sometimes the plugin works and shows his settings and is ready for "action". The NanoUSB DMX (DMX4ALL) converter installs on com10. Manual override to com2 via deviceadmin (windows). After starting the software the pluginmanager in DMXC tells me com1. Set to com2 resulting in error opening comport. After a few trys it work end it looks OK. After restart DMXC thinks go bad again. Olso setting DMXC from German to English isn't working. It keeps comming back in "German".
    I have started all-over on an new vista OS (out of the box) and heving the same problem. I have 1 XP-box and did a setup XP. Same problem. I am doin something wrong but I don't know what and where. Working with DMXC and Magic 3D incorporated works fine. I have a show in 7 days. The show is programmed and ready. Now only the lights must go on and off.
    Any help will be highly appreciated.
    Kind Regards and thanks in advance
    Paul
