New Magic 3D Easy View March 19 2010
  • I just did a fresh install of DMX Control ( because I broke the original install, dont ask :( ) and let it grab Magic 3D Easy View on its own.
    Theres a new version of Easy View!
    As usual with Nicolaudie, there is no mention of the changes anywhere, but there is one obvious one!
    They have moved to ther SSL2 scan library format and there is a new scan library editor.
    The XP menu option to start the Editor doesnt work, I had to manualy browse to /SLMEV/scanlib.exe I'm not sure if this was due to it having been previously installed on the old version or not. I did remove the original versions of DMXC and Easy View before reinstaling.
    The editor has changed significantly, lots of new options (most dont work yet).
    Everything still seems to work with the older .SSL files as well as the new .SSL2 files so the custom device files we have created still work.
    I'm not sure how to upgrade just the Magic 3D Easy View for DMX Control without a full reinstall of everything, but a reinstall shouldnt be destructive as long copies of your DDF's, SSL's and projects are saved somewhere safe. I just copy the entire /Program Files/DMXControl and the /SLMEV directories as well as the directory that I use for my projects to another folder, computer, or USB drive regularly anyway. It makes it really reliable to move entire projects from machine to machine as long as everything stays in the same places and versions.
    The only other change that I noticed right away is that Easy View seems much faster both to load and render than the previous version.
  • Hello,
    I noticed one more change at the grafic engine. (My Version 30.April 2010)
    That could be the reason why startup works much more faster - but be careful !
    I copied a gym with attached stage with easy view (Picture is attached). Just for fun i copied seating too.
    With former Versions of Easy View it took 30 - 60 seconds to load stage.
    Now it loads within 15 seconds !
    But be careful, if Shadows are enabled !
    To load my stage with enabled shadows you have to wait more than 4 minutes !
    Some more numerical Data about used RAM (of computer):
    330 Objects, 59 Fixtures used
    without "Advanced" and without "Shadows": ~94MB
    with "Advanced" and without "Shadows": ~105MB
    with both: ~542MB
    But they didn't solve one bug about grafic engine when pressing "STRG"+"ALT"+"ENTF" or when computer used screensaver or energy-saving mode of the screen, because the window of the stage remains white like at former Versions of Easy View.
    Black
