VB6 freezing when using serial port
  • Hi i'm using the Sample output template for writing a plugin for my own interface.
    Unfortunately i can use C# so i'm blocked with the old visual basic
    The trouble is:
    i've added that code to the SetChannel function to send the value via the com port.
    Note that the com port is a virtual com port (via usb cdc) and thus the transfer is extremely fast.
    When i run that code, dmxcontrol freezes and the visual basic too!!
    I've tried everything but it seem doesn't want to work!!
    Any help will be appreciated
