Problems with Alpha version
  • Bugs in alpha version 18.11.2005.
    Opening effect or scenelist disables the ability to change value on a channel in submasters, channel overview and graphical overview.
    This makes it very hard to make new scens. You have to close the scenlist and set the new values open scenlist to store them and close it again. I see this only in the alpha version.
    The english version of the alpha has a lot of german terms. But that could probably be expected of a alpha version.
    /Magnus
  • As far as i know, your problem is the new priority system.
    Maybe you can work it out with HTP
    (Look in the Preferences for "Highest takes precedence")
  • I think that DayLion is right.
    In the Program Configuartion window try ticking the Deactivate "Highest takes precedent" mixing option.
    7th option down if yours is in German.
    This should sort out your problem.
    As for the German text, I should have the full English language files available for download on my web site in a couple of days. With instructions on how to add them to the software.
    http://www.nextec.co.uk/SW_Download.shtml
    Richard
