DDF File creation
  • I attached a .txt of a ddf file im creating (ADJ_COB_CANNON_LP200X_test.txt). Im having a issue with channel 6 where when i move the slider within device control to the right side where im assuming "off" should be it doesn't turn off the colortemp channel but instead drops to 16. I need this value to be at 0-15 so i can use rgb. If I could get guidance on this that would be awesome.
    Thanks
  • Stefan March 1, 2026 at 7:09 PM
