Hi
I have been testing the newest build of version 2.8 and have found a couple of bugs.
In the Graphical view, what is the difference between 'move' mode and 'selection' mode as all of the operations appear to be the same in both modes?
In the Program configuration screen, if you set a value for the size of the icons in the Graphical view other than 32, it causes an error message each time you enter the Program configuration screen.
When you change a value in the Program configuration screen DMXC tries to error check the value when you are entering it rather than when you leave the setting box.
I will post other things as I find them
Richard
