Help please!
  • Hi, I have downloaded the latest alpha release from the english web site. i would like to know how do i edit the steps that are generated in the image generator, the tilt and pan channels patch across perfectly, but the gobo and colour channels stay a value zero??
    i have tried mostly everything and i am now stuck... the spiral would be an awesome effect if i could just get a gobo and colour to be selected while the effect is running.
    Thx for an awesome program....
  • You can select a scene for every point in the figure.
    In the moving-scene-configuration window you'll find a list on the bottom left. With the green plus you can assign scenes, whitch in turn can change gobos, colors and so on. Everything "normal" scenes can do.
