Posts by AndySummers
    Hello
    I have a ENTTEC Storm 10 that I can control using ArtNetSharp - If I add a 2nd one, can it be on the same IP Subnet? If so, how do you tell ArtNetSharp which client to send to? The PortConfig seems to be on the ArtNet instance and I can't see any way to associate the Port with a client, so I assume ArtNetSharp is sending the same data to all clients? Or would ports 1-10 be the first device and then ports 11 -20 the 2nd device? in which case how is 1st device & 2nd device determined?
    thanks
