Hello,
Thank you for your advice in solving the problem. To clarify the use of the lights, I used one DDF (3ch) for movement and then 8x Generic RGBW (4ch). Following your advice, I examined my version again and realized where I had made a mistake.
In DDF, there is a dimmer control in one channel for movement, which is key for the subsequent functioning of each additional light, although it is possible to dim each of the 8 bulbs separately. I removed this dimmer after testing. I realized it was a mistake when you posted the diagram for 35-channel operation.
Now everything is clear to me, and it has provided me with valuable information about the functioning of the DMX system and DMXControl 3 software.
While we're on the subject, is it possible to export the DDFs that are
used in the project?
Thank you for your time.
Pavel
Posts by Netus
Hello,
When creating the project, I created a test project where I tested how to control the ADJ Sweeper Beam light. I managed to do this in the test client, but when I use it in my main project,
I can't get the light to work. Is it possible to find out which DDFs are used in the test and whether I made a mistake when adding DDFs to the main project? I am attaching both files.
Thank you for your support. -
Hello JP,
Thank you very much for the explanation. It took me a while to understand this perspective, but once I programmed it, it became clear to me. I will definitely be able to use this method for my other lights, where I was blindly
using the manufacturer's preset programs. Thanks again.
Pavel
Hello community,
does anyone know if it is possible to control the
Eurolite LED PIX-144 light with some kind of program?
The only working DDF file I found was for 24 channels,but in this mode, each of the 8 segments needs to be dimmed separately, and I haven't been able to come up with a more flexible system.Thank you, Pavel
great, thank you very much.
I restarted the device and set up a new project and lo and behold.
After turning on the light, the light turns on correctly to the desired value.
Thank you very much for your time.Pavel
Thank you both very much for your help.
Unfortunately this syntax did not change the situation.
I have found that if I move the thumbwheel in the Device Control Menu and set it to zero, the thumbwheel stays at 8 in the channel overview.
Unfortunately, as a beginner, this still doesn't make sense to me and
thank you very much for any other ideas.
Have a nice evening, Stefan,
thank you for the addition and the instructions.When I load the lights, the default setting is that the value on channel 7 is set to "8"...when I set it to 0, the strobe turns off.Unfortunately, I can't keep it that way and it keeps coming back. Please where do I write what value to the ddf file?
Hello,
Thank you for your kind welcome.
in an effort to improve the file I am sending this...the device is working, only I can't remove the strobe after turning on the light. Thank you very much for your help in solving the problém purchased a Noodle device recently and am very pleased with how well it works.Best Regards
Pavel
Good day,
please check the file vs table.
I am a complete beginner. When uploading DDf, an error occurs."There has to be at least one "closed" range / step
Best regards
