Posts by roobLight
    Just as a little closure for me and future historians: I got this working (on a M1 Pro)
    • QLC+ 4 Shows to QLC+ 5 Visualizer
      (any connection)
    • QLC+ 4 Shows to Pro DMX 2 (Studio DMX Visualizer)
      sACN on localhost as unicast(!). Obviously my Vodafone Station can't handle multicast- which must both have been an oversight and a trap as well...
    Will have to switch to my Windows machine shortly and try some more (also with DMX Control) and might update this answer right here.
    Glad I made it- congratulations to myself.
    ... finally I don't have any reason to procrastinate programming our show any more! Or wait- the 3D stage needs a little brush up, still :/
    Hey there,
    wanna revive this awesome thread a little, if you don't mind. I love your approach Shween!
    I had reproduced everything like you proposed, but so far I've only got this setup to work twice within a timespan of several weeks and to this day it's not reproducable- is there a certain order it HAS to be run?
    I was successfully ingesting ArtNet into Pro DMX 2 on the same machine (WIN 10, KM-Test Loopback Adapter) and controlling faders with my show data originating from DMXC 3.3.0.
    But I just cannot get this to work reliably (or at all anymore). I think I am aware of the ports issues and everything, so now I'm thinking maybe while giving it "just a few more tries" I am always too fast switching between which app to start first (TX or RX) and don't give it enough time for the socket to being released?!
    OR- is this the exact order it has to happen EACH AND EVERY TIME?!
    7. Open Pro DMX 2 -> Create a New Project AND SAVE AS! -> click Tools -> Options -> ArtNet -> Input -> Make Sure Network Adapter is set as your Virtual Loopback IP Address
    It's sad that there's so little documentation for Pro DMX 2...
    Not even sure if I've got to NOT check the network-adapter to bind to on the startup-dialog and then only later configure it via the settings dialog?
    In the end I tried to switch to using sACN, but couldn't make that work either- probably didn't understand what that configuration needs.
    @IlluminateXperience maybe you've got some insights here for me?
    I've also tried setting all of this up between two machines (direct ethernet connection, 2.0.0.x addresses, 255.0.0.0 mask, Firewalls off)- ArtNetView shows that data is transceived (both directions work), but Pro DMX 2 does not get input.
    Wanted to look into QLC+ 5 beta, since it was mentioned here as well- also not working.
    Any suggestions what to check or how to debug? Any good reads?
    Your help is much appreciated.
    Cheers,
    Rob
    Danke für deine Antwort.
    Vielleicht findet sich ein „Grund“ in meiner Begrüssung: Newbie - keine Ahnung was sich gehört oder praktikabel ist.
    Mit DMX Control 3.2.3 hab ich erste Gehversuche hinter mir; einen ersten Song meiner Band hab ich mal durchprogrammiert (mit paar LED Bars und einem 4-fach Scanner von ADJ). Ich würde wegen des Timecode-Features gerne auf 3.3.0 gehen.
    Die Matrix ist neu für mich, ich hatte Material gekauft um WLED-Strips zu verbasteln.
    Wie gesagt, hatte ich für die Paneele schon Touchdesigner ins Auge gefasst, aber die Lernkurve dort ist erwartbar extrem steil…
    Sicher werde ich mir deine Vorschläge mal näher anschauen, Danke!
    Du hast nicht zufällig eine Idee bzgl. des Bitmap-Formats?
    Moinsen, Newbie hier.
    Paar Fragen zu Matrizen...
    Ich hab's geschafft mit ein bisschen Recherche (in 3.2.3) ein geerbtes SchnickSchnackSystem Paneel C100 (20x20 Matrix) per Artnet an den Start zu kriegen.
    Implementierung über 400 Generische RGB Geräte in ein Generisches Matrix Gerät gepatched. Aufgrund des 1200CH mode des Panels hat die Addressierung Lücken, da insgesamt 3 Universen genutzt werden.
    Ich hab irgendwo gelesen, dass dieses Prozedere in 3.3.0 anders funktionieren kann
    => wie denn?! Infos zu Matrizen sind über's Netz hinweg eher spärlich gesäht.
    Desweiteren: wie zukunftssicher ist diese Herangehensweise unter folgendem Szenario. Es gibt zwei dieser Panel, die für eine Bandshow programmiert werden sollen (viele Einzelgeräte, viele Kanäle). Hinzu kommen mindestens noch zwei LED Bars (jeweils bis zu 80-90 Kanäle) und perspektivisch noch DMX 4-fach Dimmer Strobo und Nebelmaschine.
    Die Bars und Kram könnten über ein ENTtec Open DMX angesteuert werden, oder es gäbe noch ein Showtec NET2/5 Pocket (Artnet/DMX).
    => Wie ist das im Nachhinein mit eventuellen Kanaländerungen für die Matrizen? Gibt's eine Batchmöglichkeit (evtl. in 3.3.0?), oder heisst das: 800 Einzeladressen ändern?
    Wie würde ich ein System mit dem gegebenen Material am ehesten aufsetzen, wenn ich z.B. die Paneele über Touchdesigner separat bespielen wollen würde und dann auch noch in SYNC mit DMX Control zu Backing Tracks... (eigenen Thread hierzu aufmachen, oder gibt's Tipps für Doku/Tutorials)?
    Last but not least zur Titelgebenden Frage:
    => Wie muss ich ein Bitmap anlegen, damit es korrekt auf der 20x20 Matrix angezeigt wird?
    Ich habe Quadrate mit 96 und 72 ppi probiert, aber egal wie man's macht, es sieht so aus, als würde stets nur der obere linke Quadrant eines geviertelten Bildes auf der Matrix gezeichnet werden. Irgendwie funktioniert das mit der Skalierung in den Matrix Settings auch nicht wie erwartet...
    Vielen lieben Dank für Hinweise und Denkanstösse!
    Robert
