I think I'm missing a concept or something. I have no trouble creating and running through cues in a cue list. However, If I notice something that is incorrect in a particular cue (like a color that I forget to change, or changed my mind about) and select "Edit--Edit in Programmer", go to the stage view and fix the problem, it looks to be fixed in the programmer, but does not get stored back into the cue. Same with a preset. Is there another button somewhere to permanently store the changes in the cue or preset? None of the buttons visible in the programmer appear to be anything like a "save changes" function. The only way I've found to correct a cue is to delete it and re-create it from scratch, a major hassle if it's a commonly used cue. (You know, like a preset that totally messes things up if you delete it...I've tried it)
