i got the error massage when i tried to load the fixture in
this is the code
XML
<device image="Ayra_Flash_60.png" type="DMXDevice" dmxaddresscount="2" DefaultDisplayStyle="PREVIEW" dmxcversion="3.1.0" ddfversion="1.0">
<information>
<ddf-library-id>XXXX</ddf-library-id> <!-- Replace XXXX with the appropriate library ID -->
<model>Flash 60</model>
<vendor>Ayra</vendor>
<author>YourName</author> <!-- Replace YourName with your name or username -->
</information>
<functions>
<dimmer dmxchannel="1">
<range range="50" mindmx="0" maxdmx="255" minval="0" maxval="100"/>
</dimmer>
<strobe dmxchannel="2">
<step type="blackout" mindmx="0" maxdmx="7"/>
<range type="linear" mindmx="8" maxdmx="255" minval="0.1" maxval="10"/>
</strobe>
</functions>
<procedures/>
</device>
Display More
the fault is here somewhere
XML
</dimmer>
i tried to set it at 00 but then the fixture doesn't turn on
