My Windows 10 computer recently replaced my light file with an older out of date ZIP. I don't remember when I saved the file if I accidently overwrote the original. Is there anyway this can be restored? I tried multiple apps but it didn't work and the file I want contains all of my import lights and cues. Thanks!
Posts by tpheron
It works! Thank you for all of your help!
Thank you and sorry for the late response but I don't know how to make that into an XML file.
Sorry but the file is not attached to the message.
Thank you so much!
When I try on my DMX controller, channel 13 has no function at all. I have tried it with all of the values and it doesn't control anything. It doesn't reset the auto mode, strobe, or speed controls. Is it necessary that channel 13 is included in the DDF?
I purchased it off of Amazon but it doesn't seem to have an instruction manual with it 😕.
Here is the link but I'm not sure if it is helpful
Mini Moving Head Light Dj Light, RGBW Moving Heads Stage Light with Sound Activated, Led Moving Head Light Beam Spot Lighting Effect DMX512 for DJ Disco Club Party Dance Wedding Bar ChristmasMini Moving Head Light Dj Light, RGBW Moving Heads Stage Light with Sound Activated, Led Moving Head Light Beam Spot Lighting Effect DMX512 for DJ Disco Club…www.amazon.com -
Hi,
I recently got a moving head light and I was hoping if someone could make a DDF for me. Channel 12 I have no use for as well as the small adjustments on the x and y axis.
Thanks!
The light is 12 channels
Channel 1: large movement on x-axis
Channel 2: small adjustments on x-axis
Channel 3: large movement on y-axis
Channel 4: small adjustments om y-axis
Channel 5 doesn't seem to have any function to my knowledge
Channel 6: dimmer
Channel 7: strobe
Channel 8: red
Channel 9: green
Channel 10: blue
Channel 11: white
Channel 12: random movement
The file now works, than you so much to both of you for your help, much appreciated!
And regarded to your question, I found a typo inside the XML file. So please try the attached DDF. At my computer, I can add it to DMXControl 3 now.
Hi,
A few months ago, someone on this forum made a DDF Library file for my lights. I have no idea how to code and this file has not worked. I was wondering if someone would be willing to write a new one for me. The old file would turn my lights red and I could not control them in any way; I will leave the code down below and the channels. The last 2 channels are unimportant, so if it is difficult to code its not a big deal.
The lights are a 7-channel system and I bought them off of amazon.
LUNSY RGB Stage Lighting 2Pack, 36LED Dj Par Lights, Uplighting for Events, Sound Activated,
Thanks so much for your help!
-Trevor
Lights information
Lunsey DJ Par Lights
Channel 1 (0-255) - Brightness
Channel 2 (0-255) - Red
Channel 3 (0-255) - Green
Channel 4 (0-255) - Blue
Channel 5 (8-225) - Strobe
Channel 6 - Color Fading
- 0-10 - Manual control
- 11-60 - Color Selection (colors controlled by Channel 7)
- 61-110 - Color shade (colors controlled by Channel 7) the bigger the values, the faster
- 111-160 Color pulse speed (speed controlled by Channel 7) the bigger the values, the faster
- 161-210 Color Transition (colors controlled by Channel 7) the bigger the values, the faster
- 211-255 Sound Control
Channel 7 (0-255) Color selection/colors shade(the bigger the values, the faster)
Original Code
XML
Display More<?xml version="1.0" encoding="UTF-8"?> <device type="DMXDevice" dmxaddresscount="7" DefaultDisplayStyle="PREVIEW" dmxcversion="3.1.0" ddfversion="1.0.0"> <information> <ddf-library-id>2063</ddf-library-id> <model>Par Lights 36 LED</model> <vendor>LUNSY</vendor> <author>Helmut</author> <mode>7 Channel</mode> </information> <functions> <dimmer dmxchannel="0"/> <strobe dmxchannel="4"> <range type="linear" mindmx="0" maxdmx="255" minval="0" maxval="10"/> </strobe> <rawstep dmxchannel="5" name="Mode"> <step caption="Off" mindmx="0" maxdmx="50"/> <step caption="Color Step" mindmx="51" maxdmx="100"/> <step caption="Color Fade" mindmx="101" maxdmx="150"/> <step caption="Color Fade In/Out" mindmx="151" maxdmx="200"/> <step caption="Music Mode" mindmx="200" maxdmx="255"/> </rawstep> <raw dmxchannel="6" name="Mode Speed"> <range type="linear" mindmx="0" maxdmx="255" minval="0" maxval="100"/> </raw> <rgb> <red dmxchannel="1"/> <green dmxchannel="2"/> <blue dmxchannel="3"/> </rgb> </functions> </device> -
I made sure all of the channels marched up with the program. When using my DMX board that I have, I can control all of the lights fine with no issue.
I wonder if it has to do with the code I was provided? I wouldn't know why it suddenly stopped working and doesn't work on any other light though.
I will keep trying though, thanks for the tip.
Hey, I'm still having the same issue, not sure if anyone has looked at the file but if so, that would be great!
Here you go, tTest Project.zipTest Project.zipTest Project.ziphank you so much! I really appreciate it!
Each light has 7 channels, brightness, red, green, blue, strobe, color fade, speed.
I also have provided the code bellow.XML
Display More<?xml version="1.0" encoding="UTF-8"?> <device image="IMG.png" type="DMXDevice" dmxaddresscount="7" DefaultDisplayStyle="PREVIEW" dmxcversion="3.1.0" ddfversion="1.0.0"> <information> <model>Par Lights 36 LED</model> <vendor>LUNSY</vendor> <author>Helmut</author> <mode>7 Channel</mode> </information> <functions> <dimmer dmxchannel="0"/> <strobe dmxchannel="4"> <range type="linear" mindmx="0" maxdmx="255" minval="0" maxval="10"/> </strobe> <rawstep dmxchannel="5" name="Mode"> <step caption="Off" mindmx="0" maxdmx="50"/> <step caption="Color Step" mindmx="51" maxdmx="100"/> <step caption="Color Fade" mindmx="101" maxdmx="150"/> <step caption="Color Fade In/Out" mindmx="151" maxdmx="200"/> <step caption="Music Mode" mindmx="200" maxdmx="255"/> </rawstep> <raw dmxchannel="6" name="Mode Speed"> <range type="linear" mindmx="0" maxdmx="255" minval="0" maxval="100"/> </raw> <rgb> <red dmxchannel="1"/> <green dmxchannel="2"/> <blue dmxchannel="3"/> </rgb> </functions> </device> -
Hi, I was provided a code for my lighting system by a member of this forum. It worked, for one light. Then when trying to do it again, the lights would automatically turn red with no input on my end. I have 6 fixtures with 7 channels each, I have checked the DMX addresses for overlapping, looked in the software for changes, and even read the manual. I don't have any control over the red and I no longer can control the first fixture, any suggestions? Thanks so much; I can provide more information upon request.
Ok, so I got the code to work for only one light. After I add a second device, It just turns red and I have no control over it. I have checked to see if I put the right DMX value in but it doesn't change. It might have to do something with the daisy chain because it is the first one in the series. Any suggestions?
Hi, I have 6, 7 channel Lunsy DJ Par Lights. I have had this issue for a while but I can never find a light in the select list that actually works and all of the functions are there. Is there any solution to this?
The first channel is the dimmer, channel 2 is red, channel 3 is green, channel 4 is blue, 5 is strobe, 6 is color fade, and 7 does not have any function on the DMX board I have.
Amazon link: https://www.amazon.com/LUNSY-Lighting…l/dp/B07DPGPRZ3
