Thanks Hoc - have placed test file there successfully , but when I click on 'Add Device" the program only seems to see the library devices?
Do I need to change the ddf library ID parameter to a value not already in use? (or delete that line?)
Posts by oldtimetim
Hi Arne,
Yes I can see all of the files in this location.
C:\"Program Files (x86)"\DMXControl3\Kernel\LibDevices
However, the folder is write protected, and even using the CMD promptC:\>attrib -r C:\"Program Files (x86)"\DMXControl3\Kernel\LibDevices
fails to remove the read only status - even though there is no error message when I put in the command. I'm at a loss as to how I can change the status of the directory now, so this is why I was asking whether I could chamge the directory where the program looks for the files to one that I can edit - I can then copy and past the DDF files that I need to that folder instead.
ThanksTim
Hello,
I have produced an edited DDF file, but cannot store it in the folder with the others - I seem unable to change the 'Read only' permission, despite several attempts to change this.
Is there a way of directing the program to load ddf files from a different location?
