Thanks, Stefan.
The solution is a little twisted, but it works fine.
And if it works, it's better to keep it that way.![]()
Thanks, Stefan.
Close ArtNetominator. Don't keep it running all the time. It worked for me.
The thread marked as solved, but I can't see the solution.
I join the question. I have a similar device (INFINITE-BAR-6x15W-OSRAM-No-limit) with six independent RGBW sources, each with a separate TILT, but a common PAN. How to create a DDF file and how to control it separately, but sometimes treating all sources as a group, so that you don't have to set them up separately.
So, I'll be waiting.
thanks
How to enable audio analyzer plugin in v.3.2? I downloaded and copied pdb and dll files into gui\plugins directory as in Wiki tutorials. In Plugin Management tab still there is only 3Dconnexion plugin. ![]()
I use KWMatik Pro-Myk interface. Cheap but works (at least on Freestyler, QLC+ and Onyx
Producent says that new firmware will fix the problem.
Thanks for you reply.
Looks like you're right. I used DMX Workshop to test send a few commands and the symptoms are the same - the devices behave randomly, unattended moves and flashes. If, as you say, the specification requires a periodic check for the presence of devices, it means that my ARTNET interface does not meet the specification. The manufacturer has probably chosen a simpler, poorer solution.
DMX Workshop and Wireshark are nice tools to watch traffic, so I checked how the programs that my interface works behave. QLC+, Freestyler and even Onyx simply stream data even when nothing has changed.
And just to be clear, I'm not complaining. If it is so in the specification it means that I am unlucky, because my interface doesn't fully support it. However, if other programs seem to ignore the requirements of the specification, is it possible to place a switch in "Advanced Interface Settings" of ARTNET interface that disables periodic sending of ArtPollRequest? Only the DMX data stream itself.
For me it would be a solution to the problem.
Regards
When I try to use ArtNet interface DMXC3 sends weird random data to it. In attachment is Wireshark dump. There is ArtPoll, ArtPollReply and some ArtDMX data and again: ArtPoll, ArtPollReply and some data. Data is send without my activity. Light react with random movements and lighting. The same interface with Freestyler, QLC+ and Onyx works well.
What should I do?
