Posts by allenheresy
    Hello JP,
    I finally did get to test what you were mentioning. Your method did do what I was looking for, however it is not very busking friendly, and lacks the ability to fade to the next position/color. With each color change, it resets that value before fading it in. So, color goes to white, then fades to the color. I think I'm going to have to use pre-programmed looks instead.
    I do think executors could be very powerful. There's just not enough documentation on how they work... at least in the English version.
    Thank you for your help!
    I am trying to set up executors, and cannot figure out how the flash button works. My goal is to have position and intensity on one cuelist, and executors assigned to colors and gobos. I would like to press the flash button, or bring up the intensity slider for that color cue. I hope this makes sense, and can someone help?
    Does anyone have any advice for how to move a group of fixtures relative? I would like to focus all of them downstage center, and move them as a group to another location. I see options for it, however it is not functioning how I expect. When changing the group relative, all fixtures jump to the same location.
    I thought I would follow up. I was able to set these pixel bars as a device (matrix of 8 rgb). I found in the effects and filters pane, there was a matrix effects tab. Those effects could be applied to the matrix of each individual fixture. That got the effect I was looking for. Then, I used the matrix device, and combined all of the pixel fixtures into one larger matrix to allow use of the more advanced effects like plasma and random strobes.
