Posts by Star Holden
    Ahh I see how it works now. Perfect.
    I have 2x DS18B20 and a voltage sensor now working with RDM !
    I have another hurdle if you would. You have been so helpful already.
    I would like to add the SET command: E120_RESET_DEVICE 0x1001
    Im hoping when called it could pull a digital pin LOW which is wired to the RESET pin of the arduino. The reason im using RDM is that I cannot get to the arduino it is 8meters up and dont want to power cycle the unit.
    Almost like identify command where the LED flashes except it just sends a digital write..
    What do you think?
    Regards
    Star
    Hi Stefan
    Many thanks for your contributon to the library. It really is exactly what im looking for.
    Ive edited the code to test it with an analog voltage sensor and it works perfectly thankyou.
    Im not sure how to display the output of more than one sensor. I would like to have temperature (sensor 0) and voltage (sensor 1)
    How could I call two sets of getSensorValue?
    Ive attached the edited code. Please could you have a look at it.
    Thankyou
    Star
    Hi Guys
    I am building a set of DMX addressable units using arduinos and the common DMX/RDM sheild. Instead of using DIP switches to set the address I wanted to use RDM.
    We have a test rig working with OLA recieving data from 2 arduinos loaded with Matthias Hertel's DMXSerial2 example code.
    Its working perfectly, we have all four channels working and RDM protocol is being sent and can be changed in OLA.
    So far so good.
    Now I wish to add code for sending analog and digital sensors back to OLA. I would like to add fan speed and temperature sensors to start.
    I also would like to change the PID's like E120_LAMP_HOURS to something more relevent (we are not using a lamp, we have DC motors and servos.
    I noticed the firmware for the PIC32 based Number1 unit is sensor capable and wondered if someone on the forum could help with adding similar code to the DMXSerial2 example.
    From what I can gather from the DMXSerial2 library, the library has a structure to send the sensor data im just not sure how to work it into the loop.
    Any help would be appreciated.
    Many thanks
    Star Holden
