Posts by bmandl
    Hello guys.
    I have a problem with windows 10 and DMX control v3. Whenever I open "add preset" windows or anything else, that opens programmer filter, I can't see any fixtures or group to add them. I have fixtures added to my project, but I just can't use them. I remember, that I didn't have any problems with Windows 7 though. I already tried compatibility mode and the problem persist. Can someone please help me.
    Thank you.
    Hello.
    My custom built Nodle U1 device is working in our home theater, where we use some generic dimmer rack. But when I try to use this dimmer device, it is unresponsible. The dimmer is working with any other dmx console, but not with Nodle. When I connect the dmx cable from nodle to dimmer it says "Dmx received" on the LCD, but then nothing happens and I can't control it. I can't find any data if this dimmer uses any special DMX signal or anything specific. Nodle definetly works, but it is strange that it doesn't work on this dimmer. Does anyone have any idea, what could be wrong?
    PS.: I am using QLC+ software if it's of any help..
    Hm, thats strange !
    If the ATMega32U4 was a new one, there must be a DFU-Bootloader which you can program with Atmels Flip-Tool via USB.
    This is so specified by Atmel and is also sold by Atmel.
    Maybe you got a "China"-One ?
    Or you haven't installed the DFU-Drivers before you tried to program with FLIP.
    Yeah, it was "China"-One. Maybe it wasn't new at all. It was definetly empty, I checked it with ISP programmer. Anyway, I loaded bootloader with my ISP programmer and then programmed it with FLIP. So, no harm at all :)
    Hi,
    there's already a bootloader on the ATMega32U4 !
    If you pull down Pin HWB and performing a Reset, the ATMega will start it's internal DFU-Bootlader.
    Then you can Upload the .hex-File by Using Atmels FLIP!-Tool via USB.
    Atmega was empty. I bought it on ebay
    Sent from my iPhone using Tapatalk
    Hello.
    I recenty built my own version of smd pcb for nodle1 with small modifications. Now, I just have to program the atmega32u4. But I can't find any information about fuse bits. Can someone please tell me which fuses must be writen?
    Thank you.
