Posts by davidgyates
    I knew if I fiddled long enough I might find out something else....
    Selecting the output plugins settings and disabling the K8062 and re-enabling it and the LED blinks very fast indeed.
    Like this it'll control only the first 7 channels regardless of how many channels you had set and appear on the output page.
    So...on startup of DMXControl it does all 512 by default, on disable/enable it does 7.
    So number of channels does appear to be being set...but not as you think they are!
    This test was consistent between restart of the app. and powering-down/up the K8062.
    I've tried also this on Windows XP and Windows 10 - both on 2.12.2 - it's consistent.
    ...my app (32 channels) blinks fast, but slow constant rate with DMXControl from clean start-up and new project.
    Doesn't change if I manually set value of channel 1 or then channel 512 as you might expect if DMXControl is setting it according to the highest DMX channel used.
    I apologise if I'm doing something incorrectly - but I'm pretty sure I'm not....
    Thanks
    Stefan, that's not the behaviour that I'm seeing - the blinking light on top of the unit flashes at a slow rate all the time.
    If I write my own software to talk to K8062 and set it to a maximum 32 channels then it blinks much faster - and updates much faster too of course.
    I'll just go check my findings. I have a very small show in a small venue with a small number of lights - DMXControl would seem to be absolutely ideal but is not usable with K8062 at the moment. - if it were just tungsten lights on dimmers it would be ok, but LEDs update from the DMX too fast with no latency.
    Thanks both for your replies.
