Posts by 69morpho
    Danke fuer die Antwort Scyte.
    Die Theorie hinter 16-bit dimming ist mir klar es stellt sich jedoch die Frage ob es ein entsprechendes Fixture Profile fuer die Software von Nicolaudie gibt. Ich habe mit Nicolaudie gesprochen, leider aber nur mit mittelpraechtigem Erfolg.
    Ich suche jetzt nach einer einfachen und getesteten Loesung die Software, DMX interface und 16-bit DMX Encoder bietet.
    Erwin
    The overall vision is to have two 25 foot long (7.5m) pendulums that naturally swing from the ceiling of the theater. At the end of each pendulums there will be an RGBW LED rigged within a focusing mini flashlight.
    Building these pendulums as well as all of the wiring for the LED is easy and already complete. The LED will be controllable with a DMX controller. Now comes the tricky part for us. We would like to be able to control the swaying movements with the same DMX controller.
    As of now we have 2 ideas for the swaying mechanism.
    Idea 1: Linear actuator. If we use a liner actuator we will mount the pivot point of the pendulum onto the actuators carriage. By controlling the actuator back and forth at a rate just ahead of the natural frequency of the pendulum we will be able to swing it back and forth gradually building up momentum or slowing it down. We want it to be in sync with the lighting, so it would have to be able to accept DMX signal.
    Idea 2: Stepper motor. With the stepper motor we would only mount a 3' (1m) arm onto the motor shaft. On the end of the arm we would mount the pivot point of the pendulum with a hinge. By controlling the stepper motor back and forth at a rate just ahead of the natural frequency of the pendulum we will be able to swing it back and forth gradually building up momentum or slowing it down. We want it to be in sync with the lighting, so it would have to be able to accept DMX signal. The stepper motor in this instance would need more torque than the linear actuator motor because it will have more leverage against its position. However, we are not sure how to go about identifying how much power our motor needs.
    The pendulum will probably weigh no more than 10 lbs. If we go with a linear actuator it does not need much strength. We have calculated that the period of the natural frequency of a 25 ft. (7.5m) pendulum is about 5 seconds, therefore we will need a linear actuator to be fast enough to travel its stroke length in 2.5 seconds. We assume that we will need 6-12 inches of stroke length to provide the pendulum sway we are looking for. So we are looking at an approximate speed of 5in./sec. (127mm/sec.)
    With both options we will want to be able to control the speed and frequency with our choreographed DMX program. This is a one time use so at this point we are looking for a system that is very affordable. We found individual DMX relay boards that communicate between DMX controller and motor, but they are like $300 each and we need one for each pendulum, and that doesn't even include hardware cost. We are looking for a complete solution for the mechanism and relay that costs hopefully less than $750 maybe more like $500 for both pendulums.
    Hello-
    I am looking for a linear actuator that
    is DMX controllable. I am hoping to simply plug it into my 12V DMX
    driver V+ and V-. I am imagining that I can program it to go back and
    forth on one ID. (For example set at 0 the actuator is at the left
    and 255 it is all the way on the right. The speed at which it travels
    is based on how slow I fade from 0-255. At 128 the actuator stops in
    the middle.) Is this realistic? Does something like this exist? Thank
    you in advance!
    -Erwin
    Hi there,
    I am programming a complex architectural installation with 3 universes
    using ETC Mosaic controllers. Unfortunately the built-in controller is
    only 2D. All fixtures are just simple RGB LEDs. I need some software
    that shows those RGB fixtures in a simulated 3D space. No need for any
    fancy beam reflections, etc. just simple circles in a 3D space
    indicating the position of the RGB fixtures and their programmed color
    over time.
    Does anybody know about a 3rd party software I could use in conjunction
    with the ETC Mosaic Designer software or the ETC Mosaic Designer
    controllers? Someone at ETC recommended "Capture" (see http://www.capturesweden.com). I haven't tried it yet but it is rather pricey...
    Thanks for your help in advance!
    Erwin
    Hallo!
    Ich suche dringendst einen DMX-Contoller der 3 Universen im Stand-Alone Mode betreiben kann. „Stand Alone“ heißt das der Controller eine Show ohne Computer abspielen kann. Am Computer wird nur ediert…
    Bis jetzt habe ich immer NicolAudie’s Easy Stand Alone Hard/Software-packet benützt, was aber nur 2 Universen im Stand-Alone Mode betreiben kann. Leider habe ich den Fehler begangen und mir 2 Madrix Plexus Controller gekauft. Jeder einzelne Plexus Controller treibt 2 Universen. Es ist aber möglich mehrere Plexus Controller zu vernetzen und 3 oder mehrere Universen im Stand-Alone Mode betreiben.
    Die Hardware ist ziemlich beeindruckend, aber leider ist die Madrix Software ausschließlich auf Macro-effekte ausgelegt und gibt keine individuelle Kontrolle über einzelne Leuchten was jedoch für meine Anwendung Grundvoraussetzung ist.
    Hat jemand einen Tipp für ein Hard/Software-packet unter EUR 3400, welches 3 Universen im Stand-Alone Mode betreiben kann?
    Hat schon jemand versucht mehrere Plexus Controller mit ArtNet mit einer anderen Software als Madrix anzusteuern und dann die Show auf den Plexus für Stand-Alone runterzuladen?
    Jeder Tipp ist willkommen. Danke!
    Erwin
    Dear all,
    I am looking for a DMX controller that can do 3 universes in stand-alone
    mode for a large-scale architectural installation. "Stand-alone" as in
    "playing back shows without a computer"...
    In the past I've used NicolAudie's Easy Stand Alone product line but
    they can only do 2 universes in stand-alone. I just made the mistake and
    bought 2 Madrix Plexus units. Each unit can do 2 universes and it is
    possible to daisy chain several units together to get 3 or more
    universes in stand-alone. The hardware is great but unfortunately the
    Madrix software is geared towards macro effects on large group of
    fixtures and doesn't give me the precise control over individual
    fixtures my application requires.
    Any advice on a software/hardware package under $5000 / EUR 3400?
    Any experience running 3 or more universes on several Plexus units via
    ArtNet in with a software other then Madrix and then downloading the
    show to the Plexus for stand-alone?
    Thanks in advance for your input!
    Erwin
