Posts by ChristopherD
    I'm making progress, the new beta was a huge help.
    Yes, I agree that moving from the ION to DMXC isn't anywhere close to a 1 to 1. Fortunately, most of what we do is very simple community theatre and small, relatively static events. Most of them cant even begin to appreciate what the ION can do and would probably be better off with DMXC :)
    Now, I need to do battle with the SLMEV visualizer which also cant handle anything but nice, neat consecutive channels for a fixture.
    A thought.....
    A potentially useful tool, would be a simple bit of software that acted like a patch bay for artnet/dmx. It would take dmx IN from a source (be it an artnet node ip or an entec) and put it OUT on another destination interface (again artnet node ip or an entec). The cool thing would be that a user could define a translation table for it that would, for example, define "anything for dmx address 12 coming from the source becomes dmx address 289 on destination. If this handled multiple universes, it could be a very useful utility.
    DMXC can already do this, using the softpatch feature, but it seems a waste to run the entire program, just to do address changing. There may be a market for a reliable, standalone, simple, "dmx patchbay" program that could generate some revenue to support the DMXC project. It could be quite useful for integrating house lighting with portable lighting for bars, dj's etc. and maybe even larger touring companies. It doesn't really need a fancy gui or anything. A simple "driver" or "service" that read a text file with the patches on start would be fine. Its not hard to create a file with two columns of numbers it cpuld easily support iuniverses and transation between them by using a notation like 1.307 to denote universe 1 address 307. Netbooks are cheap these days, second hand laptops are even cheaper, usually less than a single light, so using one as an appliance just to patch dmx isn't that dumb. Multiple IP's on a single network interface is easy so one Ethernet interface could, theoretically, do patching between two artnets.
    BTW, a brief, first, look and it MAY be possible to create a script using that word processor on steroids known as Linux that could, maybe move cues from ION to DMXC (at least simple ones, maybe...). I find string manipulation easier in Linux so that's where I'm starting. Its not going to be perfect, ever, even if it ever works.
    The good news, though is that it IS now possible to at least make some lighting happen with DMXC if the ION throws a temper tantrum. For some of what we do, some lighting, even if its manual, is still better than cancelling the show.
    Well done, Stefan and the team. and, again, thanks to all who commented and suggested things
    Christopher
    (oh. no problem for me on the German, I use Google Translate a lot for DMXC)
    Heres the situation:
    Example:
    An ETC Source 4 fixture with a Rosco iCue mirror and a color scroller
    This is three seperate dmx devices treated as one device
    The Lamp is on a big ETC dimmer pack at address 214, the iCue pan/tilt mirror is 16 bit so takes 4 dmx addresses from 120-123 and the scroller is on address 124
    This isnt an unusual situation in serious permanent theatre installations where dimmer packs handle multiplr KiloWatts of power and theres a few dozen or more of them in an electrical room so are addressed in a sequential group so they relate to circuits in the lighting grid.
    These are big boy toys and are normally controlled by a large ETC ION console costing many thousands of dollars.
    BUT! if the ION breaks down (and it has scared us on a few occasions). the show is over.
    I want to be able to at least get control of the lights and DMXControl would work great, but, without being able to specify different addresses for each part of devices like the S4 with mirror and scroller (and sometimes an iris as well) it becomes a nasty mess keeping track of what belongs to what fixture.
    Any ideas welcome. If I can make this work, it could well be one of the largest systems run by DMXControl with 96 2.4KW dimmers, well over 100 lights, plus over 12 "real" moving heads (Max 250 Entours and elations), a bunch of Elation RGB pars, and over 50 addons like scrollers, pan/tilt mirrors, irises. fog and snow machines, ArKaos Mediamaster pro and mediamaster vj, two video projectors (one on a pan tilt head) and all linked together using midi control with a 48ch digital sound board and SCS sound cue system so they can trigger events on each other.
    DMXC doing what an ETC ION does??? why not! Theres no technical reason it cant, its just a two universe DMX system with some midi event send and receive.
    If only I can deal with the device definitions so that one device in DMXC is made of mutiple sub-device definitions.
    The way ETC do it is to have seperate device definitions for a dimmer (the source 4), the scroller, the iCue pan/tilt and the iris.
    The the device (ETC call it a channel just to be confusing as its nothing to do with a DMX channel) is assembled by adding each part seperatly in the controller itself like "id=Ch 1, name=Down Stage Left iCue scroller iris, part1=dimmer, dmx address 214, part 2=icue dmx address 120-123, part3=scroller dmx address 124, part4=iris dmx address 461" all this is then shown as one device with intensity control, x/y control, a color picker and am iris control.
    If I can make this usable, the next step is to figure out how to export the shows (cue lists, timings, etc) from the ION and import into DMXC, but thats for another post probably in the development section of the forum. Right now, Id be happy just to be able to control things easily if (when) I have to.
    A side effect of making this work would be that the school and community theatre groups that use the facility coud now use DMXC for off line design and we could then use it to run their shows and just use the ETC ION for those pro lighting designers that are used to that type of gear.
    I remember a thread a few years ago about this and back then it was possible to do as everything was there except it was limited in the GUI. I think the reason was that it would get very CPU resource intensive.
    Well, with a modern CPU and the huge memory available in today's machines, I'm wondering if the limit could be removed, at least to two universes.
    Thanks
