Hello.
can somebody help me on some software for the "stage master" ???
Like fixture or libary's my system run's now on version 1.12. i don't now if this is the last version.
Peter
Hello.
Peter
Markus
Thanks Thanks Your solution works great.
The system works again, i'm ferry happy.
Do you now what's the last software version is, i have now v1,12.
Peter
Thanks for all your reactions
This manual i get from Highlite.nl
Stagemaster Pro Reset Code
1. Setup ausführen.
2. Drücke Taste Bank 1 (Taste nur 1x drücken, und loslassen!) dann
Szene Taste drücken und Code1668 eingeben
3. Drücke Taste Bank 2 (Taste nur 1x drücken, und loslassen!) dann
Szene taste drücken und Code1668 eingeben
4. Drücke Taste Bank 3 (Taste nur 1x drücken, und loslassen!) dann
5. Drücke Taste Bank 4 (Taste nur 1x drücken, und loslassen!) dann
6. Jetzt Code 168168 an der Show Buttons eingeben
This is what I try, but for me it don't work.
or I don´t understand the instruction
Greetings Peter
Hello Markus.
i 'm peter from holland.
Sorry for my bad englisch,
i read in the forum from 2010 you have the same problem i now have on the stage master pro RESET master CODE
i don't have the code and the master code 168168 don't work so i found the PDF "stagemaster pro reset code" i can not reset the code.
i try the same way as you i get a PDF to reset the code, but it dont work for me.
Please please can you tell me if you fix the problem, and how dit you do this.
Thanks Peter
