Posts by Okulus
    Hi Joe,
    the problem is, that you can only switch between scenes, and not from a part of scene to the next part. You have created scene1, which contains 6 parts; instead of that you should create 6 scenes, each with only one part (item). Then you can move forwards and backwards.
    Within a scene you can move from part to part (only forwards) with Go!
    Module is set to Scene list, Device to "Ausgewählte" = choosen or selected or similar, I don't know what is used in the english version; Channel is set to Go!, Flags = no flag or try T. Open your scene list window, select the first part of your scene; then go back to the grafical stage view window. Now you should be able to move from part to part, but there is no way back by key. You have to select again the beginning with your mouse.
    I guess the way with 6 single part scenes will be better for you !
    I hope this will bring you on the way.
    Regards Okulus
    Hi Joe,
    I am using version 2.11 beta under Windows 7/64. Tomorrow I will run a test under XP on another machine with the current version 2.10.6.
    It sounds good that it starts with G and stops with the second stroke on G. The 3rd should start the second scene of your list, the 4th stops it. H will change to to the previous scene. A second stroke on H will stop the current scene. That's the way it works on my system.
    One point: It's playing the scenes in your scene list; There should be more than one scene; if you are standing at the end of the list it behaves like you describe; then H should work to start the previous scene.
    Good Luck and bye
    Okulus
    Hello Joe,
    your machine translator is quite amusing :) , it was easier to understand your original text.
    I don't know anything about AutoHotKey and how you manage to send keystrokes; but if it works, try the following:
    I use "G" and "H" because they are near together and so I can show it in one picture. If you like to use "B" it should be no problem.
    In key control you have to select G, then under Modul -> Szeneliste. In Gerät/Funktion Choose Nächste = next, in Kanal Start/Stop, in Flags -> Umschaltmodus (Toggle). For "H" mostly the same, except Gerät/Funktion Vorherige (previous). Close with OK.
    Then you have to activate the Key control = Tastatursteuerung in the second tab from rightside in German "Fenster".
    A little window is opening. Make a hook in Tastaturabfrage aktiv, don't close it, just minimize it.
    Activate the window "Grafische Bühnenansicht" = grafical stage view or similar. Now hit G and the first scene starts. The next keystroke on G will stop the scene, another one will start the following. Allways stop a scene before initiating anything else. Otherwise both or more scenes will interfere. With "H" you go to the previous scene.
    In my system it works well, I hope it will bring you to success as well.
    Bye for now
    Okulus (Werner)
    Hallo,
    es gibt hier mehrere Möglichkeiten:
    die Datei könnte tatsächlich beschädigt sein => neu herunterladen
    das Programm als Admin starten
    die dll ist nicht registriert: Zubehör -> Eingabeaufforderung (als Admin) -> mit cd auf C:\Windows\system32 setzen, dann
    regsvr32.exe msvbvm60.dll eingeben. Die dll sollte natürlich in dieser Directory stehen.
    Bei Windows 7 kann das verweigert werden. Dann hilft es, wenn man die dll nicht auf C: lagert und in dem obigen Befehl den Pfad mit angibt.
    Vielleicht hilft einer der Tipps.
    Gruß Okulus
    Hallo,
    mein System läuft unter Windows 7/64bit. Dort befindet sich DMXControl nicht wie sonst im Ordner C:\Programme, sondern in C:\Program Files (x86). Darunter, im Ordner "Devices" befinden sich die Gerätedefinitionen als einzelne xml-Dateien. Wenn man nun in der Bühnenansicht ein Gerät einfügen will, zeigt sich eine Liste, die nach Herstellern geordnet ist. Diese Information wird aus der Definition ausgelesen, sie steht im Feld "Vendor", welches man über DDF Eigenschaften =>DDF Informationen erreicht. Bei selbst erstellten DDFs sollte man das Feld ausfüllen, dann wird's auch korrekt angezeigt.
    Gruß Okulus
    Hallo,
    ich habe gerade mal rumgespielt:
    Ich habe 4 LED Pars;
    Anfang: Neuen Effekt erstellen
    1. Schritt: 1= aus; 2= aus; 3= aus; 4= aus (seltsam, aber notwendig, sonst geht es nicht)
    2. Schritt: 1=rot; 2=grün; 3=grün; 4=grün
    3. Schritt: 1=grün; 2=rot; 3=grün; 4=grün
    4. Schritt: 1=grün; 2=grün; 3=rot; 4=grün
    5. Schritt: 1=grün; 2=grün; 3=grün; 4=rot
    Wiedergabe normal + wiederholen
    Für Schritt 1 : Einblendzeit = 0, Haltezeit =0
    alle anderen nach Wunsch
    ... und schon läuft ein rotes Licht durch eine grüne Reihe
    interessant wird es, wenn man versuchsweise Schritt 1 deaktiviert........
    Hallo,
    ich habe die 1.1 geladen und unter W7/64 ausprobiert. Ich erhalte die Meldung, dass DMXcontrol nicht im Ordner C:\Programme gefunden werden kann. Es steht bei W7/64 in C:\Program files (x86). Es werden aber trotzdem Daten gespeichert unter Eigene Dateien usw..Es findet keine kontinuierliche Speicherung statt. Nach der Fehlermeldung wird DMXControl geschlossen, während EasyView stehen bleibt.
    Es funktioniert also nicht wirklich!
    Vielleicht findet Ihr heraus, was schief läuft, die Programmidee ist wirklich gut!
    Gruß Okulus
    Vielen Dank für den Tipp, aber das nützt leider alles nichts. Es scheint ein Problem mit Windows 7 zu sein; unter XP läuft alles korrekt ab.
    Das FollowUp läuft, nur das Colorchange nicht. Da ich aber derzeit im Ernstfall mit XP arbeitete, kann ich vorläufig mit dem Fehler leben.
    Vielleicht findet ja bei Gelegenheit einer heraus, wo das Problem liegt.
    Grüße aus Köln, Okulus
    Nachdem ich die dlls ins plugin-Verzeichnis verschoben habe, kann ich sie unter -->Konfiguration->Plugins auch sehen. Die msstdfmt.dll konnte ich registrieren, wobei Windows 7/64 da herumzickt und dies nicht aus der Directory system32 zulässt. Wenn ich nun das Plugin kofiguriere und dies speichere, kommt auch brav die Bestätigung. Beim nächsten Start sind diese Eingaben aber nicht verfügbar, es kommt zu einer Fehlermeldung: Fehler beim Einlesen der Modulinformationen: Fehler 7: Out of Memory
    Das Plugin wird auch nicht unter "Fenster" angezeigt. Beim "Follow Spot Plugin" klappt hingegen alles!
    Weiß jemand was zu tun ist ?
