Is the Animation to Big?
Posts by Qasi
I had tho fix one thing, so you hhave to Change the dll again
ok, Copy the StreamDeckSharp-File from the test in kernel and GUI and try
OK, try the testtool
Ar the Buttons working?
Copy the dump here -
I Thint these are old Logs,
Can you please close the complet software, check it in the Taskmanager (Lumos, LumosGUI)
Be sure teh GUI and KernelFolder hase both Dlls i Uploaded
Start the Software
Export the Logfiles
Copy the HIDSharp.dll in the Kernel and GUI Folder
And Start DMXControl
Dose it Work?
If not, i need the Logfiles -
Can i have new logfiles of DMXControl with the new dll?
Unzip this File and Replace this DLL in Kernel and GUI and try again
Got the problem
Theis is e newer Streamdek wit a newer Product id,
I look what i can do, because the issue is in a external libary
Can you follow this instructions (Win8)
https://support.shippingeasy.com/hc/en-us/artic…et-Integration-
And Take a Screenshot like mine
But this tells me there is a issue with the StreamDeck or Firmware,
All other Software Disabled.
A Console-Window shows up and if You press a Button it changes they color
I've build a Test-Application. Please Run it
This Hapens if the StreamDeck Connects to the Software, at Plug it in ore if the Software Starts (
)External Content youtu.beContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
The StreamDeck can connect to Kernel or GUI, it hase to work on both.
Test on both maschines the Kernel with the StreamDeck.
Have you test it with the Network?
