Posts by UrosMali
Hi,
new low cost USB2DMX inteface with galvanic isolation was developed. More information can be found here:
http://www.dr-mali.si/usb2dmx/with kindest regards
Uros -
Hi Carlo,
I tried both ways, but it is true that I tried many more times with downloaded Magic 3D. I just installed everything on another computer (fourth one). I downloaded DMXControl 2.10 then when asked I checked Dwonload Magic 3D, everything installed ok, but I got the same message: "No interface or invalid password".
Regards
Uros -
Hi Hoc,
I tried "SunliteMEVP.out.dll" and I got Function call error. I used same (latest version of DMXControl and Sunlite May 2009 edition) on all the computers.
Furthermore, I am running as computer administrator so I do not expect problems due to administrator's rights.
Do you think this is a problem on Sunlite or DMXControl side?
With kindest regards
Uros -
Hi,
I am trying to setup DMXControl together with Sunlite visualization. It is Acer Aspire One running Win XP Pro SP3 plus all avalaible upates including Java and .NET framework 2.0
I have very stange issue with running Magic 3D EasyView when using Output plugin Sunlite (mevp.dll). I am sure that the dll path is right. I am able to run Magic 3D EasyView in demo mode with no problem. Also eg. MiniDMX output plugin is running ok.
Just when I start DMXControl and when it should start loading visualization I get an error message:
"No interface or invalid password." The strange thing is that I am able to run everything ok on two other computers, but just this one not.Any suggestion would be much appreciated.
Thank you and regards
Uros -
Hi,
is there a chance to support Cypress USB2DMX interface:
http://www.cypress.com/?id=1007&resourceID=1776&cache=0
or
ftp://ftp.efo.ru/pub/cypress/ps…_an45022_12.pdfIt is a simlple HID device where you need no drivers and just need to send data to EP1. All the date (ref. design, HW, SW are there on the link).
Thank you
Uros
